Skoda VRS Vibration/Wobble After Starting
Pretty much I bought a Fabia VRS 107K miles and after a few days the headgasket went.. anyway after getting this fixed and getting the timing belt and waterpump changed at the same time, once I start the car and it is started the car wiil wobble/vibrate for legit a few seconds then be fine from then on. the car is due a service and is getting done this week could that be effecting it? it was not doing it before.
Any help or point in the right direction would be great, thanks
Timing may be slightly out, but I think that would be a constant rough idle.
JRJG
Does it do this on a cold start and hot start ? if its only on cold start I would be thinking about glow plugs/glow plug circuit, if the glow plugs are not working correctly it will run rough from a cold start until it gets some heat into the cylinder.
