bonnet vents on mk2?
had a focus st last year with bonnet vents in, the rs come with vents so obviously suited my st, just wondered if anyone has done it? not sure if it would look well or look cheesey, sorry if its been asked i cant find anytjing on here or google about it
Someone has done it to their Mk2 which I've seen on the Facebook page. It looks really aggressive, and awesome.
i sense sarcasm harry lol or are you being serious? ive got a race blue pre facelift and cant decide if it will look tacky or add that bit of difference
Cool louvres did mine ;)
Dont do it is my answer
snh i read your thread i think you've done an awesome job with that, forgot you did vents on that, how much of a job was it? alot of fibreglass sanding and spraying?
SNH used cool louvres who are a company that have been around for years they press the louvres into your bonnet so all original metal just a respray will be required afterwords ,
Are they in areas where you have high pressure under the bonnet and low pressure above it?
Bottom ones feed cold air straight into the enclosed heatshield for the filter and the top ones expel hot air.
No fibreglassing as there pressed louvres. Took about 4 hours and did it while I waited, Bren at cool louvres has been around many years but stopped doing it for a while, recently started back up as more of a hobby rather than full time. Really knowledgeable guy and explained a lot and what would and wouldn't work, the bonnet will need painting afterwards so factor that in to the cost.
Well, certainly that's the idea, but it's not that easy with louvres. If the front set were a NACA duct then that would feed cold to the filter box, but extract louvres only work when the pressure on their "blow" side is below that on their "suck" side.
Fronts aren't extract the rears are.
