VRS Dashboard Faults left indicator arrow lit and door light
Hi first post on here. I've just purchased a 2010 VRS all was fine ! Soon as I turn on ignition the left indicator arrow is dimly lit then goes off as soon as you start car.
No problems untill you indicate Right when the left arrow lights dimly again and also shows the cruse control light as well.
Also very faint door open light when ignition on.
I've seen a few posts on here but not seen a resolve.
May need to get the cluster re-manufactured. There are a few places that do it.  It seems to not be a unique problem but you are right, threads that I reviewed seem to end without clear resolution.
You could call one of the cluster re-engineering places and see if they have encountered the fault to gauge confidence in it resolving fault..
A (relatively) common problem, run a quick search and you'll find plenty of other threads.
