VCDS Scan Fault
I have the fault code:
01336 - Data Bus for comfort System
80-10 - Single-Wire Operation - Intermittant
Address 17 - Instruments, 19 CAN Gateway and 46 Central Conveniance
This has been apparent since the installation of the NAV unit prior to the work on the lock mechanism.
Is this generally a broken wire ?
I had the same fault and all i had to do is to reseat the connector for the window mechanism which i had recently fixed.
