Bi xenon emergency position
Hi
vag technician changes passenger side lower arms on my yeti. Had an issue with the crub in the snow avoiding a stupid driver
any arms have been changed but the dipped beam on the bi xenons seems to be pointing well low. Reading the manual we think the car has its light in emergency mode?
can this be reset in a vcds? If so how please?
or is it a dealer only fix?
thanks
phil
Sounds like the sensor on the front suspension hasn't been refitted/connected back up correctly?
Jim
Is there one on the front also? I thought only the rear had it?
phil
I don't know for sure, but my previous Ford did - I would imagine it has to, the front or rear could be low or high depending on the exact loading.
Jim
There is indeed an emergency mode for the headlights that reduces the range quite considerably. I had mine reset at a dealer after an accident last year.
ok
VW guy who did my car is going to check tonight and see what he can do
Did you get the lights sorted?
