Rear left caliper OEM number?? HELP ASAP
HELP!
Does anyone know the OEM rear left brake caliper number (unpainted)? really need it since mine has seized today and my yearly inspection is shortly...
thinking of source one second hand of the junkyard.
witch vag cars have these as well?
thankfull fore all the help i can get :)
Not certain but I'd suggest Polo 9N and the same Mk Ibiza.
Ring a few breakers they will have some in. I bought one recently for £30 delivered. There will be cheaper ones around if you have the time to search.
JRJG
JRJG
Thanks Jrgj!
but isnt theretwo types of rear calipers?
all breakers/scrapyards ive talked too want the oem number to compare. and what i found out searching different brakeshops is that the golg mk4 looks similar but are 38mm like the vrs but some are 41mm?
polos, fabias and ibizas isnt quite common here(sweden) so there is no good info on it in the swedish vag forums:( :(
so if anyoen knows the oem nuber it would mean the world to me :)
19 hours ago, vindaloo said:
http://www.vwspares.co.uk/product_info.php?products_id=1588
OEM part numbers listed in the description.
J.
Thanks vindaloo!!
just one more question tho.
is this caliper fitted to more vag cars stan the polo/ibiza/fabia?
  • Sponsor
Go to this page, and sequence through the audi/vw/skoda/seat tabs (tweaking the region back to europe each time) and you'll see all models that feature that part number. Repeat for the suffix-D number if you like.
Edited by Wino
