Information ?
Hi guys just after some info really, recently changed from a 08 pre fl vrs to a 12 plate fl vrs, question is my 08 plate has cd changer and bolero, but my new one has columbus but no cd changer or the cubby hole in boot for it? Is that right? And can I fit cd changer to it?
Also the fl has xenons and fogs, can I activate the cornering function?
Any help cheers guys
I was always of the opinion that a CD changer and surround were an optional extra but I may be corrected by another reply.
I would have thought that they can be fitted if required.
The original purchaser chose the options when new.
If you consider that the Columbus has DL DVD drive (9.4Gb mp3 capacity), sd card (32Gb capacity) and internal hard drive (20Gb capacity) then your 6 cds which you'd get in a cd changer wouldn't put any real dent in the storage capacity of the unit, and no need to muck about swapping cds as and when you fancy a change.
Cornering should be factory activated normally..there is no any option from maxi-dot's menu to select this just only it is possible to activate-deactivate the bending xenon system and the projectors do move or not..
At least this is like my 09's factory xenon.
