Anyone put 1-9 tdi 150 in Mk1 fabia
Thinking about putting a150 Pd in fabia bohemia
its the 1-4 tdi.  I would want to put the six speed box in aswell
Is it a straight forward swap
might even consider doing a 2-0 pd if it's viable
my engine is gone and the dmf and clutch are in their last legs
99% the same engine as a Fabia VRS so yeah it will fit in the bay,but you will need to find out if the mounting points are on the shell for the engine and box :)
Could be that all mk1 Fabia shells have the same mounting points for engine and transmission,if so it will go straight in.
Would the engine bed shafts and gearbox go in ok
if its from a golf then you need to drill the block for the lower timing belt roller and swap the plastic backing late so you can use the fabia tensioner and engine mount, plastic water manifold is different on the head but fabia one fits, and the metal coolant pipe that runs around the engine from the thermostat to the heater pipe is different, 6 speed box fits but you will need the alloy mount adaptor from the fabia box, golf shafts are too long so you need vrs ones along with the vrs gear stick and cables, engine bay wiring loom and ecu, exhaust downpipe at least, thats off the top of my head anyway.
...and change all the suspension out as you have a lot more weight over the front axle....
great advice
ummmm, Another question?
1.4TDI is a 3 cylinder jobbie. How does that work exactly, when the 1.9 is a 4 cylinder?
BRAKES
Why hasn't anyone said this yet:
It's a TERRIBLE idea, don't bother, it's far more trouble than it's worth, the only parts you won't need to change are the bloody bodyshell and interior, pretty much everything else is different.
A PD100 is a much better starting point, sell the 1.4 TDI and buy a PD100 with the money, remap and enjoy.
The 1-4 is goosed
think I'll look for a replacement lump
does anyone know if the difference between the engine codes on the 1-4 is just the electrics. Injectors and turbo
so could I use an older type engine
mine is the 80 bhp bnv code
What do you mean 'goosed' please?
Is the engine/turbo destroyed due to oil starvation? If so then another one the same is the way to go, get the same code and it's a straight swap.
The 1-4 is goosed
What I'm asking is would something like an AMS bby BWB etc get me away if the ancillaries are swapped
Only asked about the 1-9 conversion because I could of had the full golf engine box etc very cheap
BBY is a petrol engine so not really suitable without a ton of other supporting mods.
Be one of those jobs that end up costing a fortune, like more than cost of buying a car running a pd150 lump.
Have to agree with Sep,  The cost would runaway I reckon. End up costing more than buying a motor with a 1.9tdi lump, especially a pd150 a 6 speed box.
What you need is my mates seat leon FR tdi with knackered turbo and gearbox, something like that would be better suited as that engine n box you can get hold of would drop straight in ( always good to have spare engine ).
in fairness what you could do is keep your transmission, fit a 5 speed flywheel to your pd150 engine and it will work with your car, obv some wiring to sort for the loom and immob to get around but thats easy. I'm using the 5 speed in my tdi rally car as it's much lighter and more compact.
