ASR wiring
Hi there
bit of a bizarre question
does anybody know what wire does what
I assume the brown is for earth
but then I'm left with blue/white yellow/blue and green/black
any help would be great
Um  why??.  What problem are you trying to fix? One wire and brown is going to be illumination and possibly the other 2 to make the contact to trigger the ecu mode. Are you trying to make it switch on with the engine every time?
I am just having a little play to see if I can get this to work for a bit of that's all baha
OK but you will need a momentary type switch not on off . You need to use a multimeter on the switch wires to see which ones make contact when it's pressed and use those. But there will be a resister in there somewhere that tells the abs that the switch has been disconnected from the wiring too. Not as simple as it looks I'm afraid.
Ah okay okay
I have a multimeter at the ready..
ah okay thanks for the information, may have to chose my next step wisely
OK
pin 2 Brown wire = Ground
Pin 3 Black/Green wire = 12v Ignition supply from fuse 25 10amp
pin 4 Blue/Yellow wire goes to pin 27 on ABS unit
pin 6 Grey/Blue wire = Illumination supply
02F37724-73AF-40D8-8E88-F6D13F21079F_zps
Ah that's great thank you,
if you don't min d me asking where did you get that diagram from?
Thanks again
It's from ElsaWin  a copy of the dealers manuals that covers all VAG models from 1995 to date
Brilliant thank you!
Well I got it to work if anybody is interested haha
tidy did you have to use a resister in the end?
No I found that not wiring in the illumination wire worked a treat!
so the ignition supply went into live
ground to ground
hen the wire that goes to the abs port 27 for the light on the switch
This is it now
