DSG issues with 2005 Octvia diesel
Hi there, I have posted on your hellos forum and used your search function for ‘DSG AND 2005’ and sadly can’t find information that can help me out, so hope you don’t mind me writing a detailed post here.
I have an excellent condition Octavia DSG diesel that I have taken on from a friend to try and fix as it has broken down a number of times with a DSG fault where the gearbox lights flash and the car loses drive. I have taken it to a Skoda dealer who has recommended replacing the selector mechanism (S1K2713041A – see PDF at this address https://goo.gl/TpTnsL) The problem is this selector is £529.29 and the car is only worth £1300 and the technician only advised ‘this would be the first thing he would try’. There is also only one of these parts in the country's dealer network apparently! Obviously I’m after some guidance from yourselves as to whether this is indeed the right direction to take.
So I guess my questions are to try and confirm:
1)    Is replacing this item first a wise course of action (I appreciate none of you have seen the car!) and are there any breakers who can find this item?
2)    Are there any Skoda DSG specialists I can run this situation by?
I have some VAGCOM logs if they help:
Preclearance:
Monday,02,January,2017,02:41:45:33490
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.3.0
Data version: 20140822
VIN: TMBBS21Z552045538   License Plate:
Mileage: 239190km-148625mi   Repair Order:
Chassis Type: 1Z (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 76
VIN: TMBBS21Z552045538   Mileage: 239190km/148625miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 1010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
Address 01: Engine        Labels: 03G-906-016-BKC.lbl
   Part No SW: 03G 906 016 BE    HW: 028 101 194 7
   Component: R4 1,9L EDC G000AG  7000
   Revision: 12345678    Serial number: SKZ7Z0D2778437
   Coding: 0000078
   Shop #: WSC 73430 790 00000
   VCID: 67DBCDC756EF06263A7-8032
6 Faults Found:
18058 - Powertrain Data Bus
            P1650 - 000 - Missing Message from Instrument Cluster
             Freeze Frame:
                    RPM: 0 /min
                    Torque: 0.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 12.31 V
                    Bin. Bits: 00101100
                    Bin. Bits: 00000000
                    (no units): 0.0
17055 - Cylinder 1 Glow Plug Circuit (Q10)
            P0671 - 000 - Electrical Fault
             Freeze Frame:
                    RPM: 882 /min
                    Torque: 54.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 13.68 V
                    Bin. Bits: 00101100
                    Temperature: 5.4°C
                    Bin. Bits: 10110000
17056 - Cylinder 2 Glow Plug Circuit (Q11)
            P0672 - 000 - Electrical Fault
             Freeze Frame:
                    RPM: 882 /min
                    Torque: 54.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 13.68 V
                    Bin. Bits: 00101100
                    Temperature: 5.4°C
                    Bin. Bits: 10110000
17057 - Cylinder 3 Glow Plug Circuit (Q12)
            P0673 - 000 - Electrical Fault
             Freeze Frame:
                    RPM: 882 /min
                    Torque: 54.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 13.68 V
                    Bin. Bits: 00101100
                    Temperature: 5.4°C
                    Bin. Bits: 10110000
17058 - Cylinder 4 Glow Plug Circuit (Q13)
            P0674 - 000 - Electrical Fault
             Freeze Frame:
                    RPM: 882 /min
                    Torque: 54.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 13.68 V
                    Bin. Bits: 00101100
                    Temperature: 5.4°C
                    Bin. Bits: 10110000
18034 - Powertrain Data Bus
            P1626 - 000 - Missing Message from TCU - Intermittent
             Freeze Frame:
                    RPM: 924 /min
                    Torque: 50.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.52 V
                    Bin. Bits: 00101011
                    Bin. Bits: 00000000
                    Bin. Bits: 10000100
Readiness: 1 1 0 0 0
Address 02: Auto Trans        Labels: 02E-927-770.lbl
   Part No SW: 02E 300 041 R    HW: 02E 927 770 AD
   Component: GSG DSG         041 0816
   Revision: 04004010    Serial number: 00000412020139
   Coding: 0000020
   VCID: 214F93DFF84B3816B43-8074
12 Faults Found:
28775 - No Communication with Gear Selector Module
            U0103 - 000 -  - Intermittent - MIL ON
18258 - Powertrain Data Bus
            P1850 - 000 - Missing Message from ECU - Intermittent - MIL ON
18082 - Powertrain Data Bus
            P1674 - 000 - Implausible Message from Instrument Cluster - Intermittent
00511 - Selector Lever (E313)
            004 - No Signal/Communication - Intermittent
18262 - Powertrain Data Bus
            P1854 - 000 - Hardware Malfunction - Intermittent
18274 - Powertrain Data Bus
            P1866 - 000 - Missing Messages - Intermittent
00653 - Selector Lever/Auto Trans Plausibility
18260 - Powertrain Data Bus
            P1852 - 000 - Implausible Message ECU - Intermittent
18261 - Powertrain Data Bus
            P1853 - 000 - Implausible Message from ABS Controller - Intermittent
18270 - Powertrain Data Bus
            P1862 - 000 - Missing Message from Instrument Cluster - Intermittent
29076 - Implausible Data Received from Gear Shift Control Module
            U0404 - 000 -  - Intermittent
18288 - Powertrain Data Bus
            P1880 - 000 - Missing Message from Diagnostic Gateway - Intermittent
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.lbl
   Part No: 1K0 907 379 P
   Component: ASR FRONT MK70      0105
   Coding: 0017025
   VCID: 3F8B35A76EFF6EE6A27-806A
1 Fault Found:
01315 - Transmission Control Module
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1Z0 907 044 H
   Component: ClimatronicPQ35 084 0304
   Shop #: WSC 00000 000 00000
   VCID: 3B7341B77AE772C68EF-806E
No fault code found.
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 1K0 937 049 N    HW: 1K0 937 049 N*
   Component: Bordnetz-SG     H34 0803
   Revision: 00H34000    Serial number: 00000001445920
   Coding: 418A0F020004140000110D000000000000087F075C
   VCID: 3A7D44B375DD4BCE959-806F
   Subsystem 1 - Part No: 1Z2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer SK351  012  0401
   Coding: 00065525
   Shop #: WSC 73430
   Subsystem 2 - Part No: 1K0 955 559 M  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 005  0605
   Coding: 00217125
   Shop #: WSC 73430
2 Faults Found:
00987 - Lamp for Brake Light; Left (M9)
            012 - Electrical Fault in Circuit - Intermittent
00526 - Brake Light Switch-F
            008 - Implausible Signal - Intermittent
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 K    HW: 1K0 909 605 K
   Component: 04 AIRBAG VW8   024 0700
   Revision: 07024000    Serial number: 00378D05P3ZD
   Coding: 0012340
   VCID: 34616A8B57B9BDBE4F5-8061
   Subsystem 1 - Serial number: 6332MSME3C340D08
   Subsystem 2 - Serial number: 6342MSME1A392308
1 Fault Found:
01228 - Airbag Cut-Off Switch for Passenger Side (E224)
            010 - Open or Short to Plus - Intermittent - MIL ON
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 F    HW: 1K0 953 549 F
   Component: Lenksäulenmodul 021 0050
   Coding: 0010042
   VCID: 3567578F5CC3A4B678B-8060
1 Fault Found:
00002 - Transmission Control Unit
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1Z0 920 910 D
   Component: KOMBIINSTRUMENT VD1 3560
   Coding: 0007401
   Shop #: WSC 00028 210 01865
1 Fault Found:
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 E    HW: 1K0 907 951
   Component: Gateway         H09 0110
   Revision: 09          Serial number: 2700104C150ACC
   Coding: 3F3F0740071303
   VCID: 295F8BFF807BF056EC3-807C
2 Faults Found:
01305 - Databus for Infotainment
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 1
                    Fault Frequency: 9
                    Reset counter: 238
                    Mileage: 219521 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:47:36
01304 - Radio
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 9
                    Reset counter: 238
                    Mileage: 219521 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:47:39
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO                3560
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
   Part No: 1T0 959 701
   Component: Tuersteuergeraet 09 0166
   Coding: 0000118
   VCID: F4E12A8B97397DBE0F5-80A1
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 H
   Component: EPS_ZFLS Kl.2       1502
   VCID: 316F639FA8AB8896243-8064
1 Fault Found:
01314 - Engine Control Module
             Freeze Frame:
                    Mileage: 9160 km
                    Temperature: 10.0°C
                    Voltage: 12.20 V
                    Voltage: 12.00 V
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 BL
   Component: 01 KSG              0301
   Coding: 81F802007F2D8505485F861004
   VCID: 7BF381B73A67B2C6CEF-802E
   Subsystem 5 - Part No: 1Z0 951 171
   Component: Innenraumueberw.008 4801
   Coding: 00000000
   Shop #: WSC 00000
   Subsystem 6 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H02 1301
   Subsystem 7 - Component:       NGS n.mounted
1 Fault Found:
01134 - Alarm Horn (H12)
            000 - -
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
   Part No: 1T0 959 702
   Coding: 0000118
   VCID: F5E7178F9C4364B638B-80A0
1 Fault Found:
00944 - Heated Exterior Mirror; Passenger Side (Z5)
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No SW: 1Z0 035 161 A    HW: 01. 01. 03
   Component: Radio FO3           0008
   Coding: 0000402
   VCID: 2C5172EB8F89E57E175-8079
2 Faults Found:
00857 - CD Changer Unit (R41)
00856 - Radio Antenna
            011 - Open Circuit - Intermittent
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
   Part No: 1K0 959 703 B
   Component: Tuersteuergeraet 06 0219
   Coding: 0000048
   VCID: 2F6B65E7BE9F9E66327-807A
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
   Part No: 1K0 959 704 B
   Coding: 0000048
   VCID: 3069669BA3A1819E2BD-8065
Address 76: Park Assist        Labels: 1Z0-919-283.lbl
   Part No SW: 1Z0 919 283 B    HW: 1Z0 919 283 B
   Component: Parkhilfe 4-Kan H04 0020
   Coding: 0001001
   VCID: 3D774FAF64F37CF6B0B-8068
2 Faults Found:
01545 - Sensor for Parking Aid; Rear Left (G203)
            009 - Open or Short to Ground
             Freeze Frame:
                    Fault Status: 01101001
                    Fault Priority: 3
                    Fault Frequency: 27
                    Reset counter: 133
                    Mileage: 220196 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:21:13
01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 12
                    Reset counter: 214
                    Mileage: 230480 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 10:41:16
End   ---------------------------------------------------------------------
Postclear:
Monday,02,January,2017,02:50:01:33490
02-Auto Trans -- Status: OK 0000
   Coding: 0000078
1 Fault Found:
             Freeze Frame:
                    RPM: 798 /min
                    Torque: 34.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.29 V
                    Bin. Bits: 00101100
                    Bin. Bits: 00000000
                    (no units): 1.0
Readiness: 0 0 1 1 1
   Coding: 0000020
   Coding: 0017025
1 Fault Found:
   Coding: 0012340
1 Fault Found:
   Coding: 0010042
1 Fault Found:
   Coding: 0007401
1 Fault Found:
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 9
                    Reset counter: 238
                    Mileage: 219521 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:47:36
01304 - Radio
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 9
                    Reset counter: 238
                    Mileage: 219521 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:47:39
   Coding: 0000118
1 Fault Found:
             Freeze Frame:
                    Mileage: 9160 km
                    Temperature: 10.0°C
                    Voltage: 12.20 V
                    Voltage: 12.00 V
   Coding: 00000000
   Shop #: WSC 00000
1 Fault Found:
            000 - -
   Coding: 0000118
1 Fault Found:
   Coding: 0000402
2 Faults Found:
   Coding: 0000048
   Coding: 0000048
   Coding: 0001001
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 27
                    Reset counter: 133
                    Mileage: 220196 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:21:13
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 12
                    Reset counter: 214
                    Mileage: 230480 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 10:41:16
Many thanks for any help and obviously apologies if this post is in the wrong place or some other faux pas has been committed...
Chris.
