Engine Breather
Hi All-
I am newbie to to this website- go clutch changer in my Skoda Octavia mk11 2005 today - but on collecting my car the garage advised that there was "small leaks from engine breather"
I am asking your help with this problem& would it be possible for me to repair myself=
Any help/advice would be appreciated.
Kind regards & thank you
Tony
Need more detail for people to respond.
Esp. Engine type, size capacity. Mileage often useful background too.
What was their recommended fix and what parts?
Hi and thanks for reply:
Skoda Octavia MK 2
Engine 1.4- Petrol
Miles: 170,000
had clutch replaced and garage advised some small leaks from engine breather?
Problems would seen engine running a little fast in idle?
I don't know if a pipe needs to change or do I need to buy breather unit
Any help will be appreciated.
Kind regards-Tony
Sounds like the Pcv unit and maybe the flex pipe connection. Would normally be a very DIY able job.  I don't know the 1.4 well so see what others post back.
Hi Thank you for advice - flex pipe connection replaced - easy DIY job -
This has fixed the problem car is now running perfect-
I was advise to add fuel cleaner after clutch replaced by garage -
I filled tank with petrol added fuel cleaner/ just add to fuel tank - advice on bottle -quanity to add to tank ( Product Name: DIPETANE- fuel lubricant/engine cleaner /this is name of product sold here in Ireland)
I do not know name in of product sold in UK
Not expensive €10 EURO per bottle / approx  £8.50 UK Sterling.
I hope this of benefit to Skoda Octavia Car owners - please note you can use Product/DIPETANE in petrol or diesel cars/vans.
Tony
