Climate control blowing hot air only
Hi, my vrs seems to have many gremlins. 1 after another at the moment so here's the new 1, the climate control is only blowing out rocket hot air & doesn't matter whet setting I have it on??????? The blower is working fine as in stronger/weaker. Any ideas anyone??? Thanks G.
Have a look at the first post here for how to do a fault code scan and see what comes up for starters.
^^ +1 start with the simple tasks first.
I had this on the day I picked my VRS up a couple of weeks ago.  Worked fine when I test drove the car, which is just my luck.  It was a long and warm drive back down the M1 :D  Read a few things online about what it could be and whether it was luck or a fix I managed to get mine back working.  Basically cycled up and down the heat range with recirculation on (but no climate) whilst blowing air through the centre two vents at full blower speed also, switched between vents and floor.  Apparently the common issues are the flap gets stuck or the temp sensor was having a wobbly.
At that point I wasn't signed up for this forum so was trying what I could to get it working.  Touch wood, its been fine for the last couple of weeks
