Help fk coilovers
New to this. Recently put fks on and the front is creaking and pinging when i turn the wheel from left to right, really annoying, everything seems tight. Thanks
Silly question but did you put the top mounts and bearings back on properly
As above ^^  and plenty grease to.
Not doubting capabilities here but if Top mounts were not renewed with bearings then lots of grease is needed.  Also the metal part of bearing sits on spring, its been installed backwards before by folk and i imagine it would give same issues you have.
Yeah everything put back on the way it should be, i have put a few cars on coilovers in my time and never had this problem never had to grease them ethier.
