Camber
Can anyone tell me the max/min factory specs for front/rear camber on the O3?
'sport chassis' and 'sport chassis RS'  Multilink rear (which I assume yours is)
Front -41'     ± 30'
Rear -1° 45' ± 30'
(max diff between sides 30')
Front -41'     ± 30'
Rear -1° 45' ± 30'
Awesome thanks @flybynite.
Apparently (after alignment) I now have -1deg 16' (L) & -1deg 04' (R) degrees of camber on the front, and I'm trying to work out if it's legit. The numbers you mentioned are the same as the max/min on the alignment results I have.
Edited by mabnz
If this is after you have lowered then you can expect a camber increase if you have not adjusted them. Your left one is technically above the factory limits (-1° 11' ) but I guess you are lower.
A bit of extra camber will not hurt, but if you brought it back to -41' it would give you something to work from. See what it drives like just keep an eye on the tyres for any odd wear or scrubbing.
