THS FMIC for TFSI, H&R FARB, 7p6 bluetooth, and glovebox MDI, FISCON basic plus Bluetooth
Still got a few bits knocking around including
THS intercooler, like an alloy S3 intercooler but bigger. £300 posted.
H&R 28mm (the big one) front anti roll bar. £160 posted (it's heavy).
7p6 Bluetooth and glovebox MDI. The loom for the Bluetooth kit incorporates the MDI, which makes it easier to jam the cables in somewhere. £180 for the complete kit posted. Needs a mic.
Fiscon basic plus Bluetooth. Works with Bolero and RNS510 and cars with Maxidot. Can use the wiper stalk rocket switch to answer/end calls and scroll through phone book in Maxidot display. Also has a few basic functions including fuel capacity, voltage, engine speed and oil temp. Displays boost pressure in bar and psi on Diesel engines only. £80 posted.
Is the Fiscon BT complete with loom and mic? Do you know if it will work on RCD300?
Edited by claudiu2s
Yes complete - I assume it will work, but I doubt you will get any functionality through the head unit, you'll have to do it all through Maxidot
