p2177, p0300 & p0301
My friend came round today with his genuine VCDS hooked it up and got these fault codes P2177 system too lean off idle, P0300 random multiple misfire & P0301 misfire on cylider 1.
looked at some of the blocks i.e 002 seemed fine, 030 sensor 2 was fluctuating as it should sensor 1 was just sat at 00111, block 032 idle was fluctuating between -1 - -4 and partial was sitting at 25%
cleared the codes and went back to block 032 no reading for partial and idle was sitting around 4 to 5%
I have had the car smoke tested and visualy inspected the hoses all seem to be in good condition. so if anyone can make any sense of that or point me in some direction much appreciated
it is a tfsi vrs I have changed evap canister and n80 changed the pcv and cam follower
