ABS sensor resistance check
The ABS sensor light is on all the time on my Fabia 2008 . The diagnostic shows it is the front left side is the problem . The sensor is seized in the hub and would it help if I knew the correct resistance measurement for a good sensor . Mine reads 2 meg ohms one  way and open circuit the other . Would check against other wheel sensor , but removing wiring plug is a real pain .
Edited by bks
poor grammer
