Another view on N75 valve
The most common symptom of N75 valve leak/stuck partially open is delay in boost build up
or a feel of lazyness, the major cause of this i feel is gumming up of the valve mechanism
due to residual oil entry from the pressure feed pipe. I was able to clear out more than one
car just by cleaning the hoses and the valve after removal with a generous spray of brake
cleaner and this have literally transformed the car back to its glory.
So instead of hurriedly replacing he N75 valve give it a go with brake cleaner and yes the best
solution would be the installation of an oil catch can.
