Problem wih interior lights and lighters
Hello , I am new user and 2 days ago I buy my first Skoda Superb 2.8 V6 . I find 2 electric problems - first one is that my interior lights not working , only my rear left door light work also my front and rear lighters (12v sockets) not work but the third one which is it in my back 12v socket work . Where is the problem , that make me crazy 2 days ! Every think (wing electric mirrors,alarm,dashboard and electric windows lights working) .Can someone to help me with more information please . Thank you and Sorry for my English .
Water damage.  Read the big sticky thread at the top of the forum.
Thank you . I will check now . If is that the problem - its expensive to be fixed ?
+1 for water ingress, read the thread at the top of page from start to finish, impossible to say how expensive it will depend on how long the water has been there. If you are equipped to tackle the work yourself then it will drop the cost but it is time consuming work so prohibitive if you are paying dealership labour prices. If you are keeping the car do it once and fix it right don't bodge it, there are great how to instructions in the thread, search is your friend.
Hello again . I checked today for any leak but my pollen filter and around it looked like new also I checked for water my carpet and it is very dry like my car coming from Skoda factory today ! I think that my problem is not there ! Also my 12v sockets work just my charger is too short for them that is my mistake ! Where will be the problem ? Maybe my central light console on the front ? How rear interior lights they have electric ? They take from front one or ? I don't know but I am sure that I don't have water leak !
Yours will be the only Superb MK1 in history not to leak then... :-p.
The area around the pollen filter is a "crap trap" - it gets disgusting around there very quickly with leaves etc.  If it is very clean it implies someone has cleaned it recently, probably to reseal the filter housing... ;)  There are several wiring nodes in the car which corrode on contact with water.  These are notorious for causing issues with the interior lights.  Car might be dry now but previously damaged from water ingress.
Also note that touching the carpet top isn't enough to know it is dry.  You need to see / feel under the carpet.  The carpet isn't in contact with the floorpan in most places - so there can be lots of water under it and you don't know.  If you get a look under the carpet you might also be able to see if there is any evidence of water having been there.
Of course, it could be something else, but really it is usually water damage.  In any case, if you are electrically minded you can buy the complete wiring diagrams from Skoda's ERWIN service (will cost around 6 euros I think).  Then you can trace back from the lights to find the problem.  You need to look at both the power and ground connections.
Edited by jimbof
"Yours will be the only Superb MK1 in history not to leak then" :biggrin:
You have to lift the carpet or at least remove the floor air vent under both front seats and get your hand in there to check for damp, they can hold litres of water undeneath and the carpet could be dry to touch. As Jim says above the leaks may have been fixed but the corrosion not sorted, to be honest if it is really clean around the pollen filter it would be a flag that someone has been in there recently. As per the previous post read the water ingress thread start to finish, lots of people have dismissed it to their cost believing the issue to originate some where else.
I will check next month everythink ! Here I don't have my VCDS and my DIAGNOSTIC CABLE !
My previous 2003 Superb I has never leaked although when it was nearly new it had a full dash out warranty job to repair a clicking cliate control servo so the pollen filter gasket may have been replaced
Hello again . I checked yesterday my car and find few problems .
Address 08: Auto HVAC        Labels: 3U0-907-044.lbl
   Part No: 3U0 907 044 A
   Component: CLIMATRONIC S B5 C  2004
   Coding: 17000
   Shop #: WSC 00028
   VCID: 316596C7F8295A8BBCD
1 Fault Found:
01322 - Control Module for Multi-Function Unit (MFA) (J501)
            80-00 - Single-Wire Operation
Address 36: Seat Mem. Drvr        Labels: 3B1-959-760.lbl
   Part No: 3B1 959 760 E
   Component: °301
   Shop #: WSC 00000 008 00000
   VCID: 2F6190BFEE1D4C7BAA9
   Component: °301
2 Faults Found:
-0003 - Unknown Error Code
            000 -  -
            000 -  -
Address 56: Radio        Labels: 3B0-035-186.lbl
   Part No: 3B0 035 186 D
   Component: Radio          BNO 0102
   Coding: 00400
   Shop #: WSC 00000
   VCID: 20436383A3C3E303233
1 Fault Found:
01039 - Coolant Temperature Sensor (G2)
            35-00 -  -
   Coding: 17000
   Shop #: WSC 00028
1 Fault Found:
01332 - Door Control Module; Passenger Side (J387)
Address 16: Steering wheel        Labels: 1J0-907-487-A.lbl
   Part No: 1J0 907 487 A
   Component: Lenkradelektronik   0005
   Coding: 00118
   Shop #: WSC 00028
1 Fault Found:
01326 - Control Module for Multi-Function Steering Wheel (J453)
   Component: °301
   Shop #: WSC 00000 065 00000
1 Fault Found:
01007 - Switch for Drivers Position; Rearward (E213)
            000 -  -
Address 46: Central Conv.        Labels: 1C0-959-799.lbl
   Part No: 1C0 959 799 B
   Component: BE Komfortgerбt HLO 0004
   Coding: 00258
   Shop #: WSC 00028
   VCID: 366FA5DB11477DB3E9F
   Subsystem 1 - Part No: 1C0959802
   Component: BE Tхrsteuer.FS KLO 0202
   Subsystem 2 - Part No: 1C0959801A
   Component: BE Tхrsteuer.BF KLO 0202
   Subsystem 3 - Part No: 3U0959811
   Component: BE Tхrsteuer.HL KLO 0202
   Subsystem 4 - Part No: 3U0959812
   Component: BE Tхrsteuer.HR KLO 0202
1 Fault Found:
01336 - Data Bus for Comfort System
   Coding: 00400
   Shop #: WSC 00000
1 Fault Found:
01031 - Central Locking Key Switch; Driver Side; Unlock
            35-00 -  -
Address 76: Park Assist        Labels: 3U0-919-283-7X1.lbl
   Part No: 3U0 919 283
   Component: Einparkhilfe        V009
   Coding: 01114
   Shop #: WSC 00028
   VCID: F8F3EBE3DBD3CBC3BB3
3 Faults Found:
01534 - Control Circuit for Left Headlight Range Adjusting Motor (V48)
            03-00 - No Signal
01533 - Terminal 56 (High Beams)
            29-00 - Short to Ground
01531 - Emergency Battery
Single wire operation means the CAN bus is is single wire mode - i.e. one of the wires is damaged / connection corroded.
Using the measuring blocks in VCDS you should be able to see if it is permanently faulty or intermittently faulty.  Could well be water damage to the loom.
Your VCDS listing is a bit mangled; you have items listed under parking which are nothing to do with parking.  Did you copy and paste it right?  Genuine VCDS?
Yes that is strange ! Hm ... i copy right every think ! Also my seat memory not work !
Hello again guys ! I have another problem ! My car few days ago show me Engine Check Light . When I checked with my VCDS I find few Different fault codes . Bank1/Bank2 too rich , Bank1/Bank2 too lean / Catalyst Warm Up / Missfire / Injector and every time was different fault codes but never all together also my fuel consumation on my dash was 13.5l/100km but on petrolstation was 8l/100km when I fuel up and calculated how many km I drove with how many liters ! My car stopped to start up engine from first time and yesterday I change fuel filter also I checked fuel pump and now I can't start my car anymore . It have electric and fuel but just not started anymore ! What can I do please !
  • 5 weeks later...
Hello guys again ! I fixed my problems with interior lights and my lighters . The problem was really heavily corroded wires under passanger seat but now I still have some problems and I think that will be again corroded cables but I dont know where I can find it ! Maybe under driver seat ? If someone can help me please .
Address 02: Auto Trans        Labels: 01V-927-156.lbl
   Part No: 8D0 927 156 DJ
   Component: AG5 01V 2.8l5V  RdW 1111
   Coding: 00103
   Shop #: WSC 00028
   VCID: 7829526794B458BD9D-5178
1 Fault Found:
17090 - Transmission Range Sensor (F125)
            P0706 - 35-10 - Implausible Signal - Intermittent
Address 03: ABS Brakes        Labels: 3U0-614-517.lbl
   Part No: 3U0 614 517 D
   Component: ABS/ESP front       1314
   Coding: 04497
   Shop #: WSC 00028
   VCID: 34EDEA2B84003061BD-515A
1 Fault Found:
01119 - Gear Recognition Signal
            35-10 -  -  - Intermittent
   Coding: 17000
   Shop #: WSC 00028
   VCID: 31EEEC327817024CD5-5178
2 Faults Found:
01336 - Company Data Bus for Comfort System
01341 - Control Module in Instrument Panel On Comfort CAN (J285)
            27-10 - Implausible Signal - Intermittent
   Coding: 00118
   Shop #: WSC 00028
   VCID: 2FE0E03C70190E42C5-515A
1 Fault Found:
Address 17: Instruments        Labels: 3U0-920-xxx-17.lbl
   Part No: 3U0 920 941 C
   Component: KOMBI+WEGFAHRSP VDO V04
   Coding: 31115
   Shop #: WSC 00000
   VCID: 34EDEA2B84003061BD-513C
   TMBBT63U259076484     SKZ7Z0D2434000
1 Fault Found:
            49-10 - No Communications - Intermittent
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    0001
   Coding: 00006
   Shop #: WSC 00028
   VCID: 7021627F745C8885DD-515A
1 Fault Found:
   Component: °301
   VCID: 2FE0E03C20190E42C5-513C
3 Faults Found:
01008 - Note; Emergency OFF Switch is Active!
            000 -  -  - Intermittent
00668 - Supply Voltage Terminal 30
            002 - Lower Limit Exceeded - Intermittent
00000 - End of output
            000 -  -
   Coding: 00258
   Shop #: WSC 00028
   VCID: 36EBD6218C7E24738D-4B32
3 Faults Found:
            37-10 - Faulty - Intermittent
00928 - Locking Module for Central Locking; Front Driver Side (F220)
            27-00 - Implausible Signal
   Coding: 00407
   Shop #: WSC 00000
   VCID: 20D1026F34ECA8D55D-4B18
2 Faults Found:
00852 - Loudspeaker(s); Front
            36-10 - Open Circuit - Intermittent
00853 - Loudspeaker(s); Rear
   Coding: 01114
   Shop #: WSC 00028
   VCID: 7829526794B458BD9D-4BCA
2 Faults Found:
01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
            03-00 - No Signal
01545 - Sensor for Parking Aid; Rear Left (G203)
            37-00 - Faulty
Also my wipers speed switch not work on first position . Only on fast speed I have wipers ! Thanks !
How did you fix the coroded wiring under passanger seat mate ?
  • 4 weeks later...
I just seal the corroded wires but now I have 2 new problems . My rear right door not locking and unlocking with remote control and normal also not indicate open door on my dash and when I open it my interior lights not working  (rear right door) . Also my driver door sometime have the same problem but only sometime but indicate open door and when I open it I have interior lights hm.... . Also I find electric on my rear right door electric window when I am on ignition off . Maybe broken wires again or .... ? Can some one help me Please !
