Electrical Wiring diagram help - Octy 3
Hi all, does anyone have a wiring diagram for the steering column loom on a 2017 Octavia please?
I am trying to locate the colour of wire that runs through the 'horn push' and out of the steering column to the horn relay under the bonnet (which I assume is an earth switched circuit)
I will have a look tonight not sure it will be for a 2017 though. However I suspect it is not as simple as you think I suspect it is all controled by the modules attached on the CAN bus.
John
