2010 Scout noise on camber turning left
Hi My 2010 Skoda scout 2010 petrol  has a clicking noise from the passage side which is very random seems to do it only if turning on a camber or if I brake very very hard ( emergency stop) , I’ve had to the  garage they can’t find anything- they took the wheel off when i was there and had a look and went for a drive in it .  The noise doesn’t really happen till the cars warms up a little  – I looked at the cv joints bushes etc had those all checked and nothings wrong there .  All I can think of is it must be suspension or brakes carriers—on the driver side I did see one of the stretch bolt which hold the mounts needed a couple of turn which ive done made no difference—the other one is under the battery tray though so I can’t see it – is there any easy way of getting it off . or checking. The only other thing is the tyre seem really worn on the outside edge on that side the tracking rod looks ok and i cant see damage to the spring or shock, Any ideas!
