ABS, ESP and (sometimes) tyre pressure light comes on
Hello all! I'm new to this forum and really need some help.
I got a Skoda Fabia mk2 sport 2010 5dr. While driving for some time, ABS and Esp comes on. After i turn the engine off and start the car again, the signals disappear and come back again after driving some miles.
The weird thing is, that sometimes the tyre pressure monitor also lights up, and latley all three are going on together.
I know i must go to a trusted garage but before i do, does anyone have an idea why all three are going up and sometimes only 2?(abs and esp)??
thank you!
ABS (Anti-lock brake system) And ESP (Electronic Stability Program) Are kinda linked so it may be quite normal to have them illuminate together...
If the tyre pressures are low, that may affect the ABS and the ESP so it also follows that this could be linked!  Check your tyre pressures, with a RELIABLE gauge, when the tyres are could. Get them as close as possible to the recommend pressures (And as close to each other on each axle).  Remember, warm tyres will read a higher pressure so don't rely on warm tyre pressure checks and DONT let air out if checked warm! You could theoretically have many faults and even, many faults together. Elimination is the key. Get everything right first, then perhaps get any codes read if the problem persists.
