Help required in key fob programing
At the moment the default to unlock my Skoda Octiva 2011 is one press the drivers door, 2 presses all other doors.  is there a way of just pressing once and all doors are unlocked.  i do have a vag com so any help is much appreciated.
There is a way and IIRC also one which controls which doors open when the ignition key is removed.
Using VCDS
Make sure all the doors are unlocked
Open VCDS > Go into address 09 > Coding > Long Coding > Untick Selective Locking
If you have a Maxidot you can change the settings there without vcds
For a 2012 car you can do it through the Carista App.
Below are all the changes you can make on windows, locks etc: just a part of a long list.
I bought and used a cheap wireless OBD reader for use with an iPad. Bought it initially to switch on the DRLs but have now used it for other features on the car. Italic text below is from the Carista website.
Each particular car's supported settings can be different, but here's a sample list of settings from a user with a similar vehicle:
Skoda Octavia 2012
Doors / Windows / Remote:
Auto-lock doors when moving
YES / NO
Auto-unlock doors when key is taken out of ignition
YES / NO
Auto-lock trunk when moving
YES / NO
Unlock trunk when doors are unlocked
YES / NO
Blink turn signals when locking/unlocking with remote
YES / NO
Allow configuring beep when locking/unlocking
YES / NO
Beep when locking with remote
YES / NO
Beep when unlocking with remote
YES / NO
Unlock doors via remote
DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND / ALL DOORS ON 1ST PRESS
Enable settings for opening/closing windows and sunroof
YES / NO
Open/close windows and sunroof via long-press on remote
YES / NO
Open only driver's window via long-press on remote
YES / NO
Open sunroof via long-press on remote
YES / NO
Close sunroof via long-press on remote
YES / NO
Sunroof action when opening via remote
SLIDE / TILT
Open/close windows and sunroof by holding key in door lock
YES / NO
Blink turn signals when done closing windows via remote
YES / NO
Enable smart key buttons when ignition is on
YES / NO
Hi Eddie i have tried this but for some reason it is not keeping my new setting any ideas?
if you have two keys try the other key in the ignition
or as you are in Norfolk, I'm over in Great Yarmouth if you want to have a look
Will try the other key and come back to you i am also in great yarmouth so not to far if it doesnt work.
Hi Eddie i have tried the 2nd key and its still keep putting the tick back in, unless im doing something stuipd?
I take it when you have unticked it, you come out of the coding helper to the actual page where it shows you the old and new coding with the option to "do it"
look at 13:40 to show you what i mean
Hi Eddie cheers for all your help on this finally got there, would you know where i can change the setting so that once i start driving it locks all doors?
