any mods for lighting compartment next to steering wheel
Looking for a mod to put a small light in the pull out draw next to the steering wheel, something that only comes on when its opened, perhaps a small led ??
Do you have footwell lighting on your car?
Not sure never noticed , but will check
Non footwell lights, removed the side panel thinking I could use a jumper fuse, even the fuse box has been moved
Edited by skippy41
Drop the glovebox down and the fuse box is behind there. Run a wire from there, behind the dash and use a switch like below and a LED from eBay.
 https://www.maplin.co.uk/p/v3-style-alarm-tamper-switch-nf21x
The other more complicated option is to use an unused pin on the 09 body module, you could code it as ambient lighting but this is more difficult.
