Coding diesel injector
Hi Guys
Need to replace a diesel fuel injector on my 2010 Octavia and was wondering if it is a like for like swap do i need to carry out any coding work and if so how. I do have VCDS but i am a very basic user.
Many thanks
    Address 01: Engine       Labels: 03L-906-023-CAY.clb
Control Module Part Number: 03L 906 023 AG    HW: 03L 906 023 AG
  Component and/or Version: 1,6l R4 CR td H23 5697
           Software Coding: 00114016032500080000
            Work Shop Code: WSC 73430 031 00999
              ASAM Dataset: EV_ECM16TDI02103L906023AG 001003 (SK35)
                       ROD: EV_ECM16TDI02103L906023A_001.rod
                      VCID: 6BD581E882284D1E4F-803E
1 Fault Found:
9837 - Injector: Cylinder 1 (N30)
          P0201 00 [237] - Circuit Malfunction
          MIL ON - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 155052 km
                    Date: 2084.14.01
                    Time: 12:19:44
                    Engine speed: 809.50 /min
                    Normed load value: 37.6 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 69 °C
                    Intake air temperature: 32 °C
                    Ambient air pressure: 1000 mbar
                    Voltage terminal 30: 13.666 V
                    Unlearning counter according OBD: 40
                    Environmental conditions-LF_STATE_ACT_INJ[1]: 1
                    Environmental conditions-LF_STATE_PPS_SPI[0]: 0
                    Environmental conditions-CAPA_INJ_MAIN_0_ENVD: 32.1 µF
                    Environmental conditions-CHR_INJ_MAIN_0_ENVD: 1426.300 µAs
                    Environmental
Edited by skaterboy
Hi,
After you replace the injector you need VCDS to code it in. In the injector head you have a number which needs to be typed into engine/security access or login/adaptation on the injector you're changing .
Thanks Claudiu2s
Just awaiting the new injector- I have noticed that all the four (4)original  INJECTORS seem to have a Zero (0) added after its number . I take it i will need to add a Zero (0) to the new injector.
Edited by skaterboy
