skoda octavia vrs fl front discs &pads price
could anyone give me a rough price on
skoda octavia vrs fl front discs &pads price fitted
Fixed price from skoda is £295. I'd expect an independent to be cheaper and you might find the dealer will price match if they use genuine parts.
many thanks for your quick responce,
when i go on gsf car parts it gives me two differnt sizes for the discs then when i go on euro parts just one size this is to do it my self,
https://www.gsfcarparts.com/parts/service-parts/brake-discs-pads/brake-disc
http://www.eurocarparts.com/brake-discs
The price will depend on what parts you want to use and the labour. (Stating obvious). Using aftermarket products and a lower cost garage could be as low as £150. Skoda upper end £300, with options and combinations in between.
The vRS will be 312mm front disc rotors.
Many thanks for your help
Ordered brembo  discs and pads from Euro parts £127:biggrin:
Edited by craigandrew
Hi, I'm looking for the same parts - do you happen to have a link to the part numbers you ordered?
Mu front pads/discs need replacing too - cannot complain as they have lasted 91k miles!
Been quoted £270 from my local indi for parts and labour, which I'm happy with.
What's up with you lot, get out there & do it yourselves (while the weather is fair), it's not rocket science.
Yeah it is relatively straightforward but sometimes the disc gets rusted onto the hub and requires several whacks with a persuader
