Number Plate Surround
Hi,
Apologies if the is in the wrong place but, I have got some number plate surrounds to go on my Octavia VRS, my current plates are stuck on with adhesive fixings, before I rip those off can anyone please confirm whether Skodas already have the screw holes on the front and rear?(To secure the plate holders with.)  I'd hate to pull them off and then find out I need to start drilling the car (Which I'd probably mess up)
Many thanks.
There are holes on the rear, the problem is due to the shape on the boot lid if you use the pre drilled holes the ends of the surround isn't flush with the body work. You either need to drill more holes or use double  sided sticky tape on the ends. I can't remember if the front is pre drilled or not .
