Alarm beep
Hi can I set my alarm to beep? Lights Flash etc.? If I can how do I set it up? It's a 64 plate 1.2  Fabia SE. Thanks in advance.
you need VCDS mate and the relevant cable :)
So basically I can't do it?
course you can mate the program is free but the cable is pricey and its pretty straightforward
My lights Flash when I turn alarm on/ off but doesn't beep can this be set up?
Carista ?
2 minutes ago, Shepherd113 said:
Carista ?
Whats Carista?? I'm not sure what you mean.
See this link :- http://www.caristaapp.com/
Search Briskoda as there are plenty of threads on here about it.
Thank you.
FYI : They were turned off as a EU directive some years back, as an annoying unwanted noise that disturbs local residents. Or some such.
Which probably means beeping would be an mot failure. Probably not tho! :)
Edited by stooz
add more
Skoda has passed two MOT's with the lock and unlock beep fine! I used carista and a cheap amazon 10 quid wifi obd2 dongle! :)
ooh! £10 dongle? does allow me to do things with android apps on my phone to read my car data?
With Android you have to use a Bluetooth adaptor or wifi. Apple doesn't work with Bluetooth hence WiFi.
But having a OBD2 dongle will allow you to change the settings of the car (not loads but the lock and unlock beep is on there) using Carista which doesn't cost much. I diagnosed my DPF sensor failure using that app also set needle sweep in start up, the lock beep, unlock all doors on one press and big MPH on maxidot.
I also use the dongle with an app called DashCmd which allows me to see all the intake sensors, coolant sensors, boost, etc etc on like a virtual dash board!
Tbh I would say having a wifi / bluetooth dongle in your car is always very helpful if your car throws a fault you can read it / clear it and it also works on other cars too.
I have this - https://www.amazon.co.uk/LUJII-Interface-Wireless-Diagnostic-Scanner-Wifi-Ver/dp/B01EDICW1Y/ref=sr_1_6?ie=UTF8&qid=1510158772&sr=8-6&keywords=obd2
