First service, wheel alignment failed notice.
Hi, had my octavia serviced last week at 17,000. All good apart from I was given a sheet that states wheel alignment failed, I asked is it upto them to correct it and they said " no next time I get new rear tyres I need to have it done then and not before,  I'm guessing it could be another 10,000 miles till I need new rear tyres as the tread was around 7mm. Is this definitely not something I could push for under warranty, the car has had a fairly easy life never hitting a kerb and can not recall hitting any potholes.
Not likely under warranty - doubt any dealer will say anything other than wear and tear. Speed humps are another possible culprit for knocking out the alignment?
I use Newtown Tyres for tyres and alignment by the way, and find them excellent. They don't even charge me for checking alignment - only if adjustment is needed. :)
Are your tyre pressures regularly checked and correct.
Those Wheels/tyres could and should have been moved front to rear and then the alignment checked again and adjustment made.
Is the Alignment done as part of the Servicing at no extra charge?
That is a nice touch, but allowing tyres to expire prematurely is not 'Simply Clever' of them.
Take a car into another service, for a second opinion and for a realignment - if still necessary.
This is total toe, doesn't show toe of each wheel. Seems a little less closed rear axle then it should, but not necessarily will wear more - actually probably less. If the car doesn't play with rear end when you going straight, but holding a line well, this is nothing to worry about.
I do not see the logic in 'helpfully' taking the time to carry out an alignment check and report the results but not offer the service to correct the alignment.  It's a pretty bad business model and worse still, poor customer service.
I personally wouldn't wait for x amount of miles for a re-check as in the interim period your tyres are prematurely wearing and it could also be indicative of an issue not exclusive to wheel alignment.
Look for a reputable, local tyre fitter who offer alignment checks with a Hunter system (or similar), cost will be £35-50 which will include the check and then any adjustment required.
