VCDS errors (turbo pressure valve and coolant blocking valve)
Hey fellas,
I have an Octavia vRS MK3 2014, and right now my turbo goes "su tu tu tu" after I up-shift. If it is done with high load, it simply sounds louder (my car sounds like a supra right now lol).
Anyway, this has driven me to get a VCDS scan by my friend, and the following log has appeared (with more errors..). I do have an APR turbo muffle delete and APR intake, but it is a brand new engine (prior one died because a piston got cracked into two) without APR management software.. so just intake and muffler delete (not sure if it has anything to do with the problem).
Also, I am not sure regarding the other 3 issues beside the pressure valve, have any of you seen them before? tried looking on google but couldn't find something that relates to MK3 vRS..
Regarding the pressure valve, is it dead? is there a way to make sure it is mechanical issue and not electronic without buying a new one and replacing?
Thank you!
4 Faults Found:
15454 - Blocking Valve for Coolant (N82)
          P1888 00 [047] - Short to Plus
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 6
                    Mileage: 78452 km
                    Date: 2017.09.17
                    Time: 03:56:35
                    Engine speed: 1186.00 /min
                    Normed load value: 19.6 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 26 °C
                    Intake air temperature: 26 °C
                    Ambient air pressure: 1000 mbar
                    Voltage terminal 30: 13.906 V
                    Unlearning counter according OBD: 40
                    Engine: operating status: IS
                    STATE_LS_SAE[1]: CL
                    T_AST_SAE: 5 s
                    MAP_MES_SAE: 57 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.807 V
                    FAC_TPS_1_SAE: 16.796875 %
                    FUP_H_SAE: 5890.0 kPa
15327 - Torque Management Request Input Signal A
          P2545 00 [032] - Implausible
          Intermittent - Not Confirmed - Tested Since Memory Clear
15181 - Boost Pressure Control Valve (N249)
          P2261 00 [104] - Mechanical Malfunction
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 4
                    Mileage: 80836 km
                    Date: 2017.10.16
                    Time: 19:34:51
                    Engine speed: 2427.50 /min
                    Normed load value: 0.0 %
                    Vehicle speed: 130 km/h
                    Coolant temperature: 90 °C
                    Intake air temperature: 30 °C
                    Ambient air pressure: 1010 mbar
                    Voltage terminal 30: 13.671 V
                    Unlearning counter according OBD: 26
                    Engine: operating status: PUC
                    STATE_BPA[0]: OPM
                    Charge air pressure control valve position: target value: 0.00 %
                    Charge air pressure control valve position: actual value: 0.61 %
                    MAP_MES_SAE: 25 kPa
                    Charge air pressure control valve activation pulse duty factor: -14.80 %
                    Charge air pressure control valve voltage: position closed: 3.8205 V
15304 - Engine Off Timer Performance
          P150A 00 [032] - -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 82343 km
                    Date: 2017.11.10
                    Time: 07:33:26
                    Engine speed: 807.25 /min
                    Normed load value: 7.1 %
                    Coolant temperature: 91 °C
                    Intake air temperature: 25 °C
                    Voltage terminal 30: 11.914 V
                    Unlearning counter according OBD: 24
                    STATE_LS_SAE[1]: OL_CDN
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 30 kPa
                    T_ES: 3 min
                    T_ES_CNT: 0
                    ECU_STATE: SYN_ENG_IGK_ON
Anyone?
