Brake Light Switch Location (not at pedel
Hi Just looking at my car due to no brake lights, Glow plug flashing, no cruise control and drivers window not working.  Found broken wire at door shut area but to be fixed so should clear that.  The glow light flashing lead me to brake lights not working therefore thought brake light switch but on investigation no switch at pedal.  Have any fabia's been fitted with switch at master cylinder ? as there seems to be an electrical plug underneath  it but restricted assess.  Also does the brake light failure effect cruise control or is that more likely the clutch pedal switch ? 2011 fabia  thx for any help
update re brake light switch.  Apparently skoda changed them to brake light sensor late 2010.  This is located on master cylinder in engine bay.  Any body know simple replacement procedure
Edited by AndySB
