2 smallissues
2 small issues I have with my vrs at the moment.
1 - the keeps on locking and unlocking itself while driving, think this may be battery in key fob
2 - keep hearing a faint squeak/chirp noise as I put my foot down not sure if it's just turbo noise
Bump
Chirp /squeak  can be usual, depends when and where, and at what RPM.
You have the Super Charger to 2,400 rpm and Super & Turbo to 3,500 rpm, then Turbo only.
Then various under certain acceleration.
Do you know yet if your map is standard or if re-mapped maybe.
Do you know if the Supercharger Insulation is removed. What the exhaust is, de-cat or any pipe difference?
Has the Water Pump been replaced.  How many miles has the car done?
If not done, or the 2 belts replaced that might be something needing done on a 2011 car.
Door issue can be the common problem with wiring at the door.
ie wire cut. shorting.
So is anti-hijack / autolock working ok at 6mph.  then what happens does a door open warning show, or is it like the Autolock unlocks?
Edited by AwaoffSki
Anti hijack kicks in fine at 6mph but then every so often it will just randomly unlock and then lock again
