Headlight Washers
Hi Guys,
My headlight washers have stopped working for whatever reason and I've read this is a MOT failure: -
1. Any ideas how to repair this and
2. Surely it's not a MOT failure??
Thanks, as always....
fuse number 36 -20amp for bi xenon. (cabin fuse box)
Yes it will fail as it is a requirement to keep bi xenon headlamps clean to prevent dazzle.
If not that check connections. it can only be those things or a failed pump, you could use a test lamp on the pump connections (or a meter) to see if power is getting there.
Cheers mate
