after enabeld HHC front assistant stop working
i have skoda octavia  2014  with Front Assistant ( radar )  every think was work fine
i do this  with program VCDS
Activare HHC ( Hill Hold Control )
1. 03- ABS Brakes
2. Coding-07
Long Coding
Change Byte 25 value from 40-> 43
i do this  but  the radar front assistant not work
i dont have any message  error
can  any one help on this
1. 03- ABS Brakes
2. Coding-07
Long Coding
Why did you make the change in the first place? (HHC??) Have you tried reversing to see if the FA then works again. If it does then what ever you are trying to achieve is not through this setting or not achievable.....
If it doesn't work then maybe you have a hardware fault (doubt that though if all was fine before the change)
Edited by RoboOp
hill hold control  was not  enabled   when i buy the car  not  in reversing and forward >   i search how can  i enabled  this  and found  this coding
1. 03- ABS Brakes
2. Coding-07
Long Coding
and   its work  fine
and enabled  the sweep needle  after that    radar  in front  did not work
i scan for any errors no error
how can i test the radar if it work ???
