Beep Beep Beep
Ok, its driving me mad, my new Yeti keeps beeping about every two minutes !!! What is it ?
Low temperature (4°)
Low fuel
Low washer fluid
Low coolant
I guess you are getting the picture by now.
You don’t have a dash camera do you?
no :sadsmile:
Low fuel
Low washer fluid
Low coolant
definitely not the first two, she's tucked up for the night now so i will check in the morning thank you, but wouldn't some sort of symbol show somewhere?
Low battery charge?
Had a customer complaining of bleeping every so often when they were driving.
No messages or warning lights on the car.
After a test drive I pinned the noise down to their new mobile phone.
I said your new phone is receiving texts.
The reply was ' what is a text'. I tried not to laugh.
Thanks AG Falco
You get a bleep when outside temp reaches 4 deg and you get a flashing snowflake next to temp if the air temp goes to 5 deg in about  half a mile then back down to 4 deg it will beep again
There can be so many beeps for so many things but there should be some kind of visual warning as well.
First thing i usually try is putting all seat belt buckles in.
Good guess on the phone then.
Thanks AG Falco
