jimmer69
Hi all, does anyone know if the SE-Technology 1.5 comes with air vents, 12v outlet & a USB in the rear seats arrear?
There have not been many reviews/tests of base SE/SE-Tech Karoqs yet, but from the ones I have seen, the following is likely. The brochure is of course unclear.
Rear air vents - 100% yes
Rear 12v socket - probably yes
Rear USB ports - probably not
Rear USB ports are not really a problem as you can buy a good dual-port 12v to USB insert for less than a fiver from Amazon.
Below review shows the rear of what appears to be a UK SE-Tech model. SE and SE-Tech should be identical in the rear. The only difference being that SE-Tech gains satnav, ACC and Triton alloys (all shown). Look around the 4:53 mark for vents and 12v socket. I could not spot any rear USB ports, but they can be added easily.
Edited by Orville
Thanks Orville ,it does look like the SE has the vents & 12v socket. In two weeks time I will know for sure... cheers
Same here. My 1.5 SE-Tech is due for delivery at the start of March..
