Rear tyres wearing on inner edge
Hi, My rear tyres are wearing on the inner edge. The passengers side is worse than the drivers side.
Tyre size is: 225/45/17
What can this be down to? Do I need a 4 wheel alignment?
I had my front wheels aligned by national tyres over a month ago. I didn't notice they were wearing on the inside edge then.... maybe because they werent that bad that's why I didn't notice.....
You need to find somewhere who can perform a proper full 4 wheel alignment check and can adjust the castor and camber angles not just the toe in/out
Thats the exact problem I had when I got my Oct 2 Scout .... the tyres had worn on the inner edges, and Where they were worn it wasn't even.....some block worn more than others.  The tyres were some sort of Falkens.
I put 4 new Conti Winter Contacts on and then had a full 4 wheel alignment done...... the pre alignment graph was pretty much red on everything :D
A year or so later when I replaced the Contis the wear was even on the rears :)
It's excessive camber on the rears.  They need to set it at around -0.75 and with minimal toe-in.
Just doing the front wheels is a waste of money.
Getting new tyres on the rear and a four wheel alignment this week
