Swing radio in a Elegance model
Question does this radio have reduced volume when reversing?
I ask because I have a Pure 600 and using AUX with the pure plugged into the aux socket the volume is dropped when reversing.
But I've now connected the Pure via FM and reduce volume when reversing no longer works for all FM stations.
Since I've had the Pure fitted after a month of getting the car I can't remember if radio volume was reduced prior to the Pure fitting.
If the swing doesn't reduced the volume for the radio. It must be the swing reduces on aux only or the Pure reduces vol using aux but not FM.
Swing radio does reduce volume when reversing, at least it does in my RS.
OzFabia thanks for the reply.
As mine only works for aux and not the radio I suppose I'll need VCDS to correct it?
I'll ask the VCDS forum.
Sorted chrisw880 showed me the pdc option in the radio settings
