1.9tdi sharan dropping into safe mode
Dad's 1.9tsi sharan keeps going into safe mode (no boost). Has had a new fuel filter and boost pressure sensor.
Autoscan below:
Friday,02,March,2018,19:02:36:42399
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.2.0.3 (x64)
Data version: 20180212 DS287.0
www.Ross-Tech.com
VIN: WVWZZZ7MZ8V006699   License Plate: LR57YDN
Mileage: 171080km-106304mi   Repair Order:
Chassis Type: 7M (7M - VW Sharan (1996 > 2010))
Scan: 25 01 02 03 08 09 15 16 17 18 19 22 29 35 36 37 39 45 55 56
          76
VIN: WVWZZZ7MZ8V006699   Mileage: 171080km-106304miles
Address 25: Immobilizer        Labels: 7M3-953-257.lbl
   Part No: 7M3 953 257
   Component: IMMO                0008
   Coding: 00003
   Shop #: WSC 00000
   VCID: 76E46A485262A2F432-4B38
   WVWZZZ7MZ8V006699     VWZ1Z0G2928761
No fault code found.
Address 01: Engine        Labels: 038-906-019-AJM.lbl
   Part No: 038 906 019 PA
   Component: 1,9l R4 EDC 0001AG  9325
   Coding: 00001
   Shop #: WSC 00020
   VCID: 65C63D04FFC4596C8B-4B06
2 Faults Found:
18000 - Altitude Sensor / Boost Pressure Sensor
            P1592 - 35-10 - Implausible Correlation - Intermittent
17964 - Charge Pressure Control
            P1556 - 35-10 - Negative Deviation - Intermittent
Readiness: 1 2 0 0 0
Address 02: Auto Trans        Labels: None
   Part No: 09B 927 750 L
   Component: AG5 Getriebe 09B   0260
   VCID: 3566AD440FE4E9ECFB-5160
1 Fault Found:
01166 - Engine Torque Signal
            03-10 - No Signal - Intermittent
Address 03: ABS Brakes        Labels: 7M3-907-37x-ABS.clb
   Part No: 7M3 907 379 H
   Component: ABS FRONT MK25      0102
   Coding: 0007177
   Shop #: WSC 00020 000 00000
   VCID: 428CC6981E2A4E544E-517C
1 Fault Found:
00668 - Supply Voltage Terminal 30
            008 - Implausible Signal - Intermittent
Address 08: Auto HVAC        Labels: 7M3-907-040.clb
   Part No: 7M3 907 040 J
   Component: CLIMATRONIC MPV GP  0007
   Coding: 00020
   Shop #: WSC 00020
   VCID: 3566AD440FE4E9ECFB-25AE
Address 09: Cent. Elect.        Labels: 7M3-962-258.lbl
   Part No: 7M3 962 258 BB
   Component: 26 Multifunkt.Einh  0004
   Coding: 04113
   Shop #: WSC 00020
   VCID: 7BF27B7C6940FF9C4D-50EA
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 1C0 909 605 F
   Component: 2G AIRBAG VW61 0Q0M 0004
   Coding: 12871
   Shop #: WSC 00020
   VCID: 275A770CC5488B7C79-5142
Address 17: Instruments        Labels: 7Mx-920-xxx-17.lbl
   Part No: 7M3 920 920 L
   Component: KOMBIINSTRUMENT VDO V68
   Coding: 13411
   Shop #: WSC 00020
   VCID: 397EA17423FC0D8C1F-5142
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    0001
   Coding: 00006
   Shop #: WSC 00020
   VCID: 70E85C5030068CC4E8-5142
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No SW: 6Q0 035 152 E    HW: 6Q0 035 152 E
   Component: Radio DE2           0003
   Revision: 00001000    Serial number: VWZ4Z4G4020741
   Coding: 0040400
   VCID: 2C5088208CAEA82494-5142
End-------------------------(Elapsed Time: 04:41)--------------------------
check the turbo vanes
