Skoda Fabia VRs Mk1 Cruise control retrofit HELP
Hi all,
Ordered the genuine cruise control kit (BEA400002) from Skoda which is compatible for my car
I have already checked guides and information relating on how to fit the kit. Some have had issues getting to the T11a pin 10 block connector and some have wired it directly to the ecu
I for obvious reasons want to keep it how it should have been installed from factory rather than slicing wires from the ecu
I have had no luck with an actual guide with pictures on how to remove that white block so I can fit the white wire to pin 10
I tried however there's too much wires and relays in place and given the time I had today before it started raining and getting dark I put back the panels and to do for another day
the only other option is to removing the dash to gain access to the T11a
So to those who actually had success wiring this - please share your experience and guides
most of the threads I looked at no longer show images for some reason so that doesn't help me in any way
  • 1 year later...
I have uploaded a video on how to find the t11a
https://youtu.be/YbitNsuprRQ
  • 2 months later...
Fahim..were are you based? Do you provide and fit cruise? What price? Thanks
