Rear windows not working , blowing the fuse
I’ve got a FL TDi VRS and the rear windows keep blowing the fuse . As you put the fuse in for the rear windows it sparks also . I’ve unplugged the rear doors on both sides and Put a fuse in and it sparks still and blows the fuse . Has anyone had this problem ? Someone has asked if you had any water in the drivers footwell and I’ve not seen or felt any and also said it could be the module itself . Any input would be appreciated.
Check the wiring, sounds like sometime may have chaffed through and is now shorting causing the fuse to blow.
