Clicking from steering wheel
My yeti has started making a clicking noise when you turn the steering wheel. The noise seems to come from directly under the steering wheel. Has anyone got any ideas
Could it be the clock-spring, do all the buttons on the wheel work?
Or maybe be the indicator cancel mechanism or the top column bearing.
CV joints particularly doing a U- turn type manoeuvre?.
Edited by Ryeman
I thought maybe the indicator mechanism. I also read a lot about it being the cv joint but as noise seems to come from directly behind the steering wheel thoughy this was unlikely. How would i check if it was the indicator
Does it always click when the steering wheel is in the same place.
Doesnt seem to no
I had this the other day.
Every time I went round a corner I heard this clink.
Go round another & clink.
After driving around for 10 hours, I finally found the answer.
Which was?
My Granddaughter had left 2 marbles in the center arm rest.
They clinked together as I went round the corner.
:D
:D
Sounds like a load of B@££$ :D - sorry couldn't resist
Seriously though - worth checking out just to make sure. I had a Fiat Punto a few years ago owned from 2 1/2 years old that had a strange steering noise - the steeering column to rack pinch bolt hadn't been er "pinched" - probably from new! Easily sorted but could have been much more serious!
Edited by bigjohn
