Window operation with remote key
When I open or close the windows with remote on the key only the drivers window moves.
I tried resetting each of the other windows in turn (open window, press and hold open again, close window, press and hold close again). The remote then opened all the windows, but only once, then reverted to just the drivers window. How can open and close all windows with the key?
Any ideas much appreciated.
There is relevant adjustment via maxidot display menu, assuming you have it.
I have maxidot but have not come across anything obvious in the menus. What am I missing? Cheers.
I don't know if you have an OBD reader?  I use the Carista version and when unlocked it allows you to activate all sorts of bits & bobs in the customise menu.  It's also useful for clearing codes etc.
https://caristaapp.com/
School boy error on my part. Just found a lot more menus within the maxidot. Didnt realise you had to press and hold the rocker switch. I really should read the handbook!
Thanks all. Sorted now.
