FL headlight water intake
I've had a sudden intake of water into my front xenon AFL headlights.
I've had the lights out multiple times and checked all the backs of the lights and they seem ok. I've also run a small need of silicone around the seam of the headlight to try and find the fault with no avail. The price for a new headlight is 450+ vat. Has anybody had similar or any other solutions I haven't thought about or tried. Thanks in advance
How has the water got in, after washing the car with high pressure system or passing over a lake of water somewhere?
 Just through rain water today again
If it gets water so simply during/after a rain then it sounds you have a crack somewhere.
Does happen in both?
Don't believe the sealant would be problematic as the age is not high for it to become dried..
Just drivers side and yeah as simple as rain can't see anything visible at Al
I would remove the headlight and check the vents are clear, driving with the dipped beam on will help them dry out.
It's just the amount getting in its not just condensation it's getting actual water running inside
It sounds to be faulty,
Not sure if it is fixable but you seem to need a new unit?
So much water gathering in should give you a clear sign of the problem though..
