boost pressure solenoid noise
Hi, is it normal for the boost pressure solenoid to make a noise, similar to a muffled duck?
I would expect some sort of noise but whether it can be heard over the sound of the engine, stereo, chatting, road noise etc is debatable.
 If you keep getting sounds of muffled, duck, try squirting some orange juice into the fuel tank. (That latter part is meant to be a joke... you will get it if you "Concentrate")!
My last fabia had this noise. I swapped the solenoid for a new one. If you do this make a careful note of the pipe layout or take a picture or 2. The 3 tubes run parallel then two of the tubes kind of criss cross near the solenoid.
Edited by m8t
