Passenger window not operating
Hi all, the passenger window on the Fabia has stopped working.  Checking with VCDS I can see that the switch is operating since this is logged in the measuring blocks.
The locking still works ok too. Guessing it could be the window motor or power to it at fault?
Is there a reset I can try via VCDS to see if this helps?
Cheers!
Ok, weird, but might help others:  using the Global Opening and Closing function on the key fob seems to have resolved this.
I fully opened all windows using the global opening, then closed all windows and the passenger window fired up!
Phew.
