Strange Steering Issue
Have this weird fault in the steering on my VRs.
The steering can intermittently jerk while turning on gentle turns. I haven't noticed it when pulling strong into a bend.
It's really hard to describe and it's made it very difficult to search for.
The closest I can get to describing it is it feels like your driving over a stone or a cutting in the road. The wheel fights the turn for a second then goes back to normal.
I had a quick look under and the only thing I could see was a busted drop link. Track rods feel ok, no major movement at least, and the 4 wheel alignment have just been done.
I find I can replicate it going from right to left. Right turns seem fine.
Any idea where to look?
On Fabias  a common problem was the steering/tie rods inner joint (inside the rack boot) seizing due to water contamination/rust. Usually most noticeable when stood or low speed maneuvering and turning slowly lock to lock, basically sticking/releasing.
The steering/tie rods are removable/changeable.
https://www.autodoc.co.uk/car-parts/inner-tie-rod-10298/skoda/octavia/octavia-1z3
Edited by xman
That would rule out the play in the joint itself I guess. I could get the stick/release when I was checking it the other evening. Worth changing them anyhow I suppose.
I would change the busted drop link first. It may be catching as you turn.
