enabling DAB on RNS315 with VCDS
I thought there was an ICE forum on here but I can't find it...
Has anyone done the above?  I noticed it on another forum where someone was enabling Bluetooth and DAB was in the tickbox above it.  My thought was to do it as follows:
http://www.ukpassats.co.uk/phpbb/viewtopic.php?t=76247
You can only enable DAB and Bluetooth if it's actually installed in the unit. The only way to check if your unit has it is to look at the data sticker and MAC address on the side (if it has a random string of letters & numbers then it has Bluetooth - all zeros means no Bluetooth), and look for a black Fakra connector on the rear which is the DAB antenna connection. If your unit doesn't have a valid MAC address and a black connector, then no amount of tick box jiggery pokery will help.
Edited by Rustynuts
good point, will have a look on mine to check, ive a feeling its just a reverse camera connector spare
