Dmf on way out ?
Hi when turning right and accelerating have noise from gearbox side, checked wheel bearing no play, not clicking like cv joint would dmf cause it when turning right ? Only does it when applying power  does not do it turning and accelerating left. Thanks.
No, it's not the DMF, check the CV joints for play.
Not ticking  noise or even there unless putting some drive through the gears
You have to actually get out of the car, get under it and have a look.
It's still not the DMF.
Possibly a damaged wishbone or its bushes.
Also, driveshafts have joints both ends so don't overlook the obvious.
