airbag light on. b13bcf2 code
Hi, the airbag  light has just come on had it checked by the local garage and showing the code 'b13bcf2 multiple collision brake - no function' anybody got any ideas. tried Googling it and it's showing as faulty slip ring. Also checked the plug under the passenger side seat and that seems ok, any help would be appreciated. Thanks
Edited by stan801
The slip ring is the connection to the airbag in the steering wheel.
  • 1 year later...
Just had same issue did you get it fixed if so what was it,,,,, VW forums suggest possible ABS module fault, thanks
